Pasi MYLLYMAKI
Question from Predictive Maintenance Webinar 29th of April: How much data does log in cloud per hour from one sensor?
    Vladimir JANOUSEK_34072
    May 12, 2020
    This can be programmed eventually of course. In the example for STWIN using the wifi expansion and cloud dashboard, you can currently set, if to get data every 10 to 60 seconds, this is done with easy to use sliders in the cloud"set streaming time" settings.
