Pasi MYLLYMAKI
Question from Predictive Maintenance Webinar 29th of April: How high bandwidth can the magnetometer provide for motor monitoring?
    Vladimir JANOUSEK_34072
    May 12, 2020
    IIS2MDC output data rate is 150Hz max in low power single measurement mode, so depending on the actual use case and bandwidth needed the usability must be evaluated
