dsouzahansen
Problem with SD card interface on Inemo
Posted on August 16, 2011 at 14:32
        Im facing a problem with the Inemo SDcard api.
Iam able to read and write multiple blocks and single blocks but Im not able to erase the card.
When I issue a command for erase and then read the block I always get 0xffff.
Has anyone faced a similar situation or knows the reason why this is happening?
Thanks and Regards,
Hansen.Dsouza
#inemo
    hafrun
    September 23, 2011
    Posted on September 23, 2011 at 02:41
    Hi Dsouza Hansen
    I have also run into some problems in my attempts to implement the firmware for the microSD card slot.  I see also that you have had no replies on your inquirer, and several other people have also posted questions regarding the microSD card without any answers.
    So I'm a bit curious to know if you have been able to solve your problem and whether you would be willing to share some of your experience?  I believe it would lead to some answers for you and benefit the community here.
    All the best,
    Hafrun
    afsanahmad
    Posted on October 03, 2011 at 10:38
    hi hafrun and Dsouza Hansen!
     i want to write sensors output to sd card. can u plz guide how to start.
    thanks
    kobihayun
    November 9, 2011
    Posted on November 09, 2011 at 13:31
    Hi Hunzai,
    Did you manage to overcome the problem with the iNEMO SD card? If yes, I will be glad if you can write what need to fix in order to make the iNEMO SD card to work.
    TNX
             Kobi
