Anil3
problem with input Raw data
HI
I am using STEVAL-MKI182v2 sensor connected to Nucleo-F446ZE Evaluation board and printing the data and found that there is no any changes between i/p and o/p data even after using the library functions and so i started debugging step by step in this process i started to log the input data of accelerometer in 4 different positions and compared them with the Unico o/p data there is very huge difference between them and one more thing is, not getting the negative values of Z-axis even though it is placed in negative z-axis direction...i am using below example code from github and printing the data.
