CALVEBest answer
Oct 31, 2019 7:37 AM UTC
Thanks. The problem is solved. Yes, as you can see in my program i check the WHO_AM_I code, and it was correct. The STEVAL-IDB008V2 implement another sensor on I2C bus (LPS25HB) with the same device address. Since i modified the address of LPS22HB, it run correctly and i read correct pressure and temperature. Regards.
