RUSHI GAJJAR
Over-molding of LSM9DS1
Posted on March 22, 2018 at 08:57
Hi, This question is regarding the e-packaging of the LSM9DS1 sensor PCBA
Instead of packaging it in the plastic casing, We are planning to cover the PCBA with the overmolding material to cover the whole PCB including the sensor to protect it from moisture and environment.
Is overmolding advisable over the LSM9DS1 sensor given that it is a MEMS? If yes, do you suggest any specific material and process?
#lsm9ds1 #overmolding #packaging
RUSHI GAJJAR
Posted on April 02, 2018 at 12:50
This has been floating for some time now, Does anyone has a view on this? It will be really helpful.
April 2, 2018
Posted on April 02, 2018 at 14:09
Potting or conformal coating?
Suggest you talk with ST customer support representatives in your area, or ST FAE supporting your account.
RUSHI GAJJAR
Posted on April 03, 2018 at 09:46
Hi Clive, We are currently putting Void/Mask region over the sensor while we do a conformal coat.
This question is rather related to the Potting/Overmolding over the Sensor and its PCBA.
Posted on April 05, 2018 at 12:51
Coating or overmolding is OK for the sensor.
Please be aware of the maximum temperature which the sensor can withstand.
