JPhil.3
April 26, 2021
On the LPS22HB SPI, what is the minimum high time for CS?
I'm communicating via SPI with an LPS22HB using an FPGA. Is there a minimum time specification between SPI transactions? I'm currently setting CS high for 0.5 SPC cycles between transactions, but this doesn't seem to work.
Eleon BORLINI
Hi @JPhil.3​ ,
I would say you have to take into account at least 1 clock pulse, since the internal logic has to understand the line has changed the polarity.
It is not directly reported in the datasheet p.12, but I would try (at least) with this value.
-Eleon
