tcg
Official library for LIS3DH with FIFO DMA transfer
HI, I am trying to develop a application with a accelerometer over 5kHz.
I have some samples of LIS3DH. Does exits any repository of mem senc?
I search in cubemx but is not there.
I can write the library from datasheet but it is a lot of time and it will not be mantain.
do you know if other device in cubemx or in c official library is supported by st?
I am interested on fifo DMA transfer by I2c .
Thanks fot all, tcg
WojtekP1
It's just I2C transfer. Can't you do anything yourself instead of just library&cut&paste?
PS. Works perfect. i used LIS3DH
tcg
tcgAuthor
yes of course, but as I said, I would prefer to know if there is an official library for maintenance and integration.
Kind regards, tcg
Eleon BORLINI
Hi @Tomás Cabeza​ ,
There is a C example for FIFO configuration on LIS3DH on Github, you can find it at this link --> lis3dh_multi_read_fifo.c.
Then once you have the data from the FIFO, you can implement the DMA transfer through STM32 / CubeMX libraries.
-Eleon
tcg
tcgAuthor
Thanks a lot @Eleon BORLINI​ .
I will try this code tomorrow. I will give you a feedback
Thanks a lot for your fast response, tcg
