DevM
Nov 10, 2020 8:00 AM UTC
Null pointer dereference using st_imu68 driver and STMems_Android_Sensor_HAL_IIO
Hi all,
I opened a issue on github about it:
https://github.com/STMicroelectronics/STMems_Android_Sensor_HAL_IIO/issues/6
Once i add the STMems_Android_Sensor_HAL_IIO library on my system the sensor service crash.
01-01 00:02:12.558 2358 2358 F DEBUG : Revision: '0'
01-01 00:02:12.558 2358 2358 F DEBUG : ABI: 'arm'
01-01 00:02:12.558 2358 2358 F DEBUG : pid: 2355, tid: 2355, name: android.hardwar >>> /vendor/bin/hw/android.hardware.sensors@1.0-service <<<
01-01 00:02:12.558 2358 2358 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x1c
01-01 00:02:12.558 2358 2358 F DEBUG : Cause: null pointer dereference
01-01 00:02:12.559 2358 2358 F DEBUG : r0 00000001 r1 00000000 r2 af5905c8 r3 00000000
01-01 00:02:12.559 2358 2358 F DEBUG : r4 af5905c8 r5 0000005a r6 00000000 r7 00000003
01-01 00:02:12.559 2358 2358 F DEBUG : r8 bebad354 r9 00000004 sl 00000000 fp bebab950
01-01 00:02:12.559 2358 2358 F DEBUG : ip af86062c sp bebab910 lr af8252ad pc af371b64 cpsr 200e0030
01-01 00:02:12.619 2358 2358 F DEBUG :
01-01 00:02:12.619 2358 2358 F DEBUG : backtrace:
01-01 00:02:12.620 2358 2358 F DEBUG : #00 pc 00007b64 /vendor/lib/hw/STsensors.msm8909.so (st_hal_open_sensors(hw_module_t const*, char const*, hw_device_t**)+275)
I don't know if this is the official way to report a bug, Otherwise let me know the right way to do it.
Thank you in advance.
    Eleon BORLINI
    Eleon BORLINIBest answer
    Nov 10, 2020 3:47 PM UTC
    Hi @DevM​ ,
    you are right, the official way to open an issue concerning those Android libraries is reporting it on Github.
    Same for the C libraries, for example.
    Please let me know if you will or will not receive a feedback (in about 1 week max).
    Edit: the topic should now be closed on Github.
    -Eleon
    Eleon BORLINI
    Hi @DevM​ ,
    -Eleon
    DevM
    DevMAuthor
    Nov 16, 2020 10:33 AM UTC
    Hi @Eleon BORLINI​ ,
    Any update on the issue?
    Thank you.
    Eleon BORLINI
    Nov 16, 2020 11:18 AM UTC
    Hi @DevM​ ,
    uhm... let me please check internally and then come back to you.
    -Eleon
