Aug 19, 2025 11:05 AM UTC
Need confirmation MSL level MPN - LIS2DW12TR
Hi Expert,
Good day.
Refer to the attached label image.
One label shows MSL 1 and the other shows MSL 3 for MPN LIS2DW12TR.
However, the Reliability Evaluation Report for this P/N indicates MSL 1. Both labels have the same COO but different MSL levels. Is it possible or Is there any PCN behind this change?
[images deleted by a moderator]
Looking for your support on this.
Thank you.
Ivan Paul
Peter BENSCH
Peter BENSCHBest answer
Sep 3, 2025 12:42 PM UTC
First of all, please note: do not post labels here in the public community, as the information they contain could be misused by counterfeiters. For this reason, I have deleted the label photos here.
In general, questions about MSL and similar topics are answered by the personal Online Support OLS. However, I can tell you in advance that no PCNs are issued for MSL and that the value stated on the label depends on the respective backend plant. I have also checked both labels internally again and they correctly indicate the respective MSL.
Hope that helps?
/Peter
ivan paulAuthor
Aug 20, 2025 4:33 AM UTC
Hi Expert,
Looking for your valuable support above query.
Thank you.
Ivan Paul
Peter BENSCH
Hope that helps?
/Peter
