PPera.1
Need Certificate of Conformity
I am using STM32WB55RG as the MCU and LSM6DSO32 as the ACCELEROMETER in my project. In order to get my project CE certified, I require the Certificate Of Conformity for the both components.
Hope you guide me to the right path.
Thank You and Warm Regards,
Pavan Kumar Perapu
Embedded Firmware Developer
Next Step Dynamics
    Eleon BORLINI
    Eleon BORLINIBest answer
    Hi @PKuma.23 Perapu​ ,
    I can share you the Material declaration form for the IMU LSM6DSO32 and the pressure sensor LPS22HB.
    By the way, I agree with @Community member​  about the fact that you will need a dedicated Certificate Of Conformity for your final product.
    If these document -at least for the sensor part- are the ones you need, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster.
    -Eleon
    March 29, 2021
    Are you sure these chip level parts need one, rather than your product using them and implementing the delivered circuit?​
    PPera.1
    PPera.1Author
    Yes, I am sure that I need the Certificate Of Conformity or Material Content Declaration for these two components and for the pressure sensor LPS22HB as well.
    Guide the way.
    Thank You.
    March 29, 2021
    A RoHs type thing or a Radio Emissions/Acceptance type thing?
    There's "CE" marks for a lot of different things.
    PPera.1
    PPera.1Author
    If possible, can you share the both of them​?
    That might help me a big time.
    Thank You.
    Eleon BORLINI
    -Eleon
    PPera.1
    PPera.1Author
    Hi Mr Borlini,
    Is that possible for you to share the same or the COC for the MCU STM32WB55RG too?
    kindly let me know.
    Thank You
    Eleon BORLINI
    One attachment per time...
    PPera.1
    PPera.1Author
    Thank You Mr Borloni.
    Yeah I agree with him too.
    I am trying to prove that every component being used in my project follows up with the RoHS presently.
    I'll, indeed, need the COC for the entire Project once it gets done.​
    Eleon BORLINI
    for some products, such as the many STM32 and in this case the STM32WB55RG, you can find the material declaration document on ST eStore.
    Here the link.
    I attach the document for completeness.
    -Eleon
