Nate
Need 8000 degrees-per-second
I have successfully designed a product which uses ISM330DHCX. However this unit only allows for a maximum of +/- 4000 dps, and within the application of the product, the gyro can saturate at high speeds.
Are there any plans on releasing a product that can measure +/- 8000 dps? This range would cover what I need.
Thank you.
Eleon BORLINI
Eleon BORLINIBest answer
Hi @Nate​ ,
a +/- 8000 dps is not in the very near development roadmap... but why do you need such a wide Full Scale?
-Eleon
Eleon BORLINI
Hi @Nate​ ,
-Eleon
Nate
NateAuthor
This is for a sports product, where the player can impart 2000 RPM on the ball.
Eleon BORLINI
Hi @Nate​ ,
understood, thank you. I'll report this input internally.
-Eleon
