Multi FSMs on LSM6DSV16X
Hi, I am trying to merge the left and right wrist tilt configuration examples so that I have left wrist tilt on the FSM1 routing to INT1 and right tilt on the FSM2 routing to INT2 on LSM6DSV16X. I am sharing the merged config and the reference configurations being used(link). I have been trying to find an example for multi FSMs in MEMS studio but can't find any. Issue is thig config works fine for right wrist but not for left wrist. Any help in this regard would be appreciated. thanks
Federica Bossi
Hi @a4ans ,
You copied the FSM part of the two configurations, but not the MLC part, which in this specific case is shared between the two FSM programs.
In addition, there were a few spurious writes that made the configuration invalid. Here is the corrected configuration:
 "json_format": {
 "type": "reg_config",
 "version": "2.0"
 "sensors": [
 "name": ["LSM6DSV16X"],
 "configuration": [
 { "address": "0x10", "data": "0x00", "type": "write" },
 { "address": "0x11", "data": "0x00", "type": "write" },
 { "address": "0x01", "data": "0x80", "type": "write" },
 { "address": "0x04", "data": "0x00", "type": "write" },
 { "address": "0x05", "data": "0x00", "type": "write" },
 { "address": "0x5F", "data": "0x53", "type": "write" },
 { "address": "0x46", "data": "0x03", "type": "write" },
 { "address": "0x0A", "data": "0x00", "type": "write" },
 { "address": "0x0B", "data": "0x01", "type": "write" },
 { "address": "0x0E", "data": "0x00", "type": "write" },
 { "address": "0x0F", "data": "0x02", "type": "write" },
 { "address": "0x17", "data": "0x40", "type": "write" },
 { "address": "0x02", "data": "0x11", "type": "write" },
 { "address": "0x08", "data": "0x7A", "type": "write" },
 { "address": "0x09", "data": "0x00", "type": "write" },
 { "address": "0x08", "data": "0x7C", "type": "write" },
 { "address": "0x09", "data": "0x02", "type": "write" },
 { "address": "0x08", "data": "0x7E", "type": "write" },
 { "address": "0x09", "data": "0x04", "type": "write" },
 { "address": "0x02", "data": "0x41", "type": "write" },
 { "address": "0x08", "data": "0x00", "type": "write" },
 { "address": "0x09", "data": "0xB1", "type": "write" },
 { "address": "0x09", "data": "0x30", "type": "write" },
 { "address": "0x09", "data": "0x34", "type": "write" },
 { "address": "0x09", "data": "0x96", "type": "write" },
 { "address": "0x09", "data": "0x31", "type": "write" },
 { "address": "0x09", "data": "0xB8", "type": "write" },
 { "address": "0x09", "data": "0x80", "type": "write" },
 { "address": "0x09", "data": "0x20", "type": "write" },
 { "address": "0x09", "data": "0x44", "type": "write" },
 { "address": "0x09", "data": "0x24", "type": "write" },
 { "address": "0x09", "data": "0x09", "type": "write" },
 { "address": "0x09", "data": "0x66", "type": "write" },
 { "address": "0x09", "data": "0xAA", "type": "write" },
 { "address": "0x09", "data": "0x23", "type": "write" },
 { "address": "0x09", "data": "0x01", "type": "write" },
 { "address": "0x09", "data": "0xA5", "type": "write" },
 { "address": "0x09", "data": "0xFF", "type": "write" },
 { "address": "0x09", "data": "0x42", "type": "write" },
 { "address": "0x09", "data": "0x0A", "type": "write" },
 { "address": "0x09", "data": "0x39", "type": "write" },
 { "address": "0x09", "data": "0x07", "type": "write" },
 { "address": "0x09", "data": "0x03", "type": "write" },
 { "address": "0x09", "data": "0x77", "type": "write" },
 { "address": "0x09", "data": "0x83", "type": "write" },
 { "address": "0x09", "data": "0x88", "type": "write" },
 { "address": "0x09", "data": "0x86", "type": "write" },
 { "address": "0x09", "data": "0x22", "type": "write" },
 { "address": "0x09", "data": "0x40", "type": "write" },
 { "address": "0x08", "data": "0xEA", "type": "write" },
 { "address": "0x09", "data": "0x72", "type": "write" },
 { "address": "0x09", "data": "0x82", "type": "write" },
 { "address": "0x08", "data": "0xFA", "type": "write" },
 { "address": "0x09", "data": "0x5C", "type": "write" },
 { "address": "0x09", "data": "0x84", "type": "write" },
 { "address": "0x09", "data": "0x90", "type": "write" },
 { "address": "0x02", "data": "0x31", "type": "write" },
 { "address": "0x08", "data": "0x5C", "type": "write" },
 { "address": "0x09", "data": "0x08", "type": "write" },
 { "address": "0x09", "data": "0x2F", "type": "write" },
 { "address": "0x09", "data": "0xA2", "type": "write" },
 { "address": "0x09", "data": "0xB7", "type": "write" },
 { "address": "0x09", "data": "0x3F", "type": "write" },
 { "address": "0x09", "data": "0x1F", "type": "write" },
 { "address": "0x08", "data": "0x84", "type": "write" },
 { "address": "0x01", "data": "0x00", "type": "write" },
 { "address": "0x08", "data": "0x90", "type": "write" },
 { "address": "0x09", "data": "0x7C", "type": "write" },
 { "address": "0x09", "data": "0xE0", "type": "write" },
 { "address": "0x17", "data": "0x00", "type": "write" },
 { "address": "0x02", "data": "0x01", "type": "write" },
 { "address": "0x0D", "data": "0x00", "type": "write" },
 { "address": "0x60", "data": "0x25", "type": "write" },
 { "address": "0x05", "data": "0x11", "type": "write" },
 { "address": "0x5E", "data": "0x02", "type": "write" },
 { "address": "0x5F", "data": "0x02", "type": "write" },
 { "address": "0x63", "data": "0x30", "type": "write" },
 { "address": "0x10", "data": "0x05", "type": "write" },
 { "address": "0x11", "data": "0x05", "type": "write" }
