kasi viswanadh
MotionFX library and MotionMC
I'm using MotionFX library v3.0.0, even if i do compass calibration, yaw value is still drifting some times. do I need to use MotionMC library to get better results?
    Eleon BORLINI
    Hi @kasi viswanadh​ , if you want to implement a compass app, I would suggest you to use the MotionEC library. In general, as reported in the UM, the goodness of the library output values for the compass is related to the magnetometer calibration: the higher the value, the better the results of the data algorithm. So I would suggest you to implement MotionMC together with the other library. Regards
    Kasi did you ever solve this?
