May 4, 2026 17:50 UTC
MotionFX is not updating orientation after suddent stop. How to trigger updating by acc+mag.
Hey, I am using MotionFx 9D, and it works pretty well, except in one case:  when a fast movement is done, and we stop, the IMU is not in the correct orientation due to the update being disabled just before the end of the movement (like a 10-30° error). As I read on that forum, this is intended behavior; however, in our application, it is a pretty useless bug rather than a feature.
We tried many thresholds, trusts, various sampling times, etc. No luck. Please provide any information on how we can control updates to achieve almost no movement. That looks like hidden settings, and we are so desperate to even inject a 'noisy' input as input data to trigger updating at the end of movement (as we have noticed that small vibrations are causing orientation to be corrected with every single small movement).
Thanks!
