wchao.1
MCU entry hardfault when I called the fuction of MotionFX_CM0P_initialize(), the sensor is LSM6DS3,
Hello bro, MCU entry hardfault when I called the fuction of MotionFX_CM0P_initialize(), the sensor is LSM6DS3,  the algorithm I am using is motionFX Library. The stack did not overflow. Do you have any good idea for this problem ? thanks!
Eleon BORLINI
Hi @wchao.1​ , please check if this thread can be of any help. They get HardFault after the call of motionFx_CM0P_Initialize() too (with ARM and STM32L031K6). Regards
wchao.1
wchao.1Author
Hi Eleon, thank you for your reply, maybe it is related to the MCU, I found that the hardware CRC initialization needs to be called before calling the library initialization, otherwise the F103 OR F429 will crash. May I ask whether this sensor algorithm can be used on the other MCU, such as NXP or Non-st manufacturer's products. thanks again!
Eleon BORLINI
These libraries can in principle be used on ARM-based micro-controllers, but the portability across different MCU families is easy only among the ST MCUs, thanks to the STM32Cube software, and is optimized for the ST MCUs interface with ST sensors... Regards
