Ritesh Patel
June 22, 2017
LSM9DS1 I2C address identification
Posted on June 22, 2017 at 09:56
I am planning to use
LSM9DS1
 9DoF sensor in our project.
As per datasheet table #2, Least significant bit for I2C address is [SDO_   A/G or SDO_M ]= SA0.
From this information & Table#19, I will be able to identify I2C address for
Accelerometer and gyroscope.
How can I set address bit 1 of SAD[1]/SA1 to identify
Magnetic sensor
I2C address?
Awaiting for earliest response.
Regards,
Ritesh.
    Petr S
    Posted on September 04, 2017 at 14:11
    Hello Ritesh,
    It seems like a typo in the datasheet Table 2 Pin description: SDO_M Pin #6 should set I2C LSB+1 of the device address (SA1) for the magnetometer while LSB (SA0) is always 0. So you can use this pin for your magnetometer identification. I'll ask for datasheet correction.
    Regards,
    Petr
