Sachin3
February 9, 2023
LSM6DSR to LSM6DSOX migration issue
We are migrating from LSM6DSR to LSM6DSOX. In LSM6DSR the nominal timestamp resolution used to be around 25 μs. And we used to get 52 samples/sec from the FIFO.
However, in LSM6DSOX with a similar setting, we are getting a resolution of around 18 μs. And hence sample has gone up to 72. What should changes be made to get similar samples as LSM6DSR
    Eleon BORLINI
    Eleon BORLINIBest answer
    Hi @Sachin​ ,
    you might limit the samples in LSM6DSOX FIFO to 52 samples with a proper watermark, and then read these 52 stored samples every second. You can have a look to the AN5275 application note, p.103, where the use of the FIFO threshold level (watermark) is described.
    -Eleon
    Eleon BORLINI
    Hi @Sachin​ ,
    -Eleon
