gabriel.arnautu
May 31, 2019 1:49 PM UTC
LSM6DSO inclinometer
I was playing around with Unico and I saw it has an inclinometer function. Is the code for that window available:? I tried an implementation with Kalman filter, but the Unico seems to show the angles much better.
Regards,
Gabriel
    Eleon BORLINI
    May 31, 2019 3:45 PM UTC
    Hi Gabriel, welcome back. Unfortunately the source code for Unico is not available... You could however manage to implement the inclinometer function using the Tilt detection using the MotionTL middleware library of the X-CUBE-MEMS1 (here). Regards
    gabriel.arnautu
    May 31, 2019 3:49 PM UTC
    Hi Eleon,
    Unico uses the same middleware?
    Regards,
    Gabriel
    Eleon BORLINI
    Jun 3, 2019 11:03 AM UTC
    ​yes Gabriel, almost similar. Sorry for my question, but are you interested in the algorithm results or in the graphical rendering of the inclinometer measure? Are you finding some lack of accuracy in using that libraries? Regards
    gabriel.arnautu
    Jun 3, 2019 11:06 AM UTC
    Hi Eleon,
    I am intrested in the algorithm, not the GUI. Tomorrow I will try to use MotionTL and see how it goes. Actually, I need it in Python, but if I have it in C I can just convert it.
