Hi @MVida.1 ,
I think you are referring to the cross axis between the various IMU axis (for example, x vs y, or y vs z for the accelerometer, and pitch vs yaw or yaw vs roll for the gyroscope).
These data are not available in the datasheet, so I can share you only typical values on a small subset of samples.
Consider also that in the gyro case the quadrature is compensated at production tester level, so you'll have to take into account of just a residual quadrature.
Keeping a "distributional" margin, the cross axis is below 2%.
If my reply answered your question, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster.
-Eleon
