jjo.2
(LSM6DSL) I want to know why raw data(angular rate) is multiplied by sensitivity.
Multiply the angular velocity(gyro raw data) by sensitivity and it becomes mdps, what exactly is mdps?
float_t lsm6dsl_from_fs500dps_to_mdps(int16_t lsb)
  return ((float_t)lsb * 17.50f);
    Eleon BORLINI
    Eleon BORLINIBest answer
    Hi @jjo.2​ ,
    "mdps" means milli degree per second, which is the measurement of an angular rate.
    You need to multiply the LSB data by a specific factor because it refers to the sensitivity according to the datasheet of the mechanical element inside the sensor.
    -Eleon
    Eleon BORLINI
    Hi @jjo.2​ ,
    -Eleon
    jjo.2
    jjo.2Author
    Thank you for your answer. One more question is, do you have a formula or example code to calculate the angle using raw data?
    I also want to know if there is an example code using a complementary filter.
    jjo.2
    jjo.2Author
    @Eleon BORLINI​
