louiey
Apr 17, 2019 6:54 AM UTC
LSM6DSL_FROM_FS_2g_TO_mg/LSM6DSL_FROM_LSB_TO_degC error from github code
Hi.
I'm trying to use LSM6DSL sample code from "https://github.com/STMicroelectronics/STMems_Standard_C_drivers/tree/master/lsm6dsl_STdC/example/read_data_simple.c" which is official url from ST.
I build code and got error due to missing of "LSM6DSL_FROM_FS_2g_TO_mg/LSM6DSL_FROM_LSB_TO_degC" definition.
I couldn't find any from this git code.
Actually "LSM6DSL_FROM_FS_2000dps_TO_mdps" definition is also missing and I could find in this forum but couldn't find rest of two.
Can you let me know where I can find these?
BR.
Louiey
    Eleon BORLINI
    Eleon BORLINIBest answer
    Apr 18, 2019 1:48 PM UTC
    hi Louiey, actually the LSB to physical conversion are defined inside the lsm6dsl_STdC/driver/lsm6dsl_reg.h as follows:
    #define LSM6DSL_FROM_FS_2g_TO_mg(lsb) (float)(lsb * 61.0f) / 1000.0f
    #define LSM6DSL_FROM_FS_4g_TO_mg(lsb) (float)(lsb * 122.0f) / 1000.0f
    #define LSM6DSL_FROM_FS_8g_TO_mg(lsb) (float)(lsb * 244.0f) / 1000.0f
    #define LSM6DSL_FROM_FS_16g_TO_mg(lsb) (float)(lsb * 488.0f) / 1000.0f
    #define LSM6DSL_FROM_FS_125dps_TO_mdps(lsb) (float)(lsb * 4375.0f ) / 1000.0f
    #define LSM6DSL_FROM_FS_250dps_TO_mdps(lsb) (float)(lsb * 8750.0f ) / 1000.0f
    #define LSM6DSL_FROM_FS_500dps_TO_mdps(lsb) (float)(lsb * 17500.0f ) / 1000.0f
    #define LSM6DSL_FROM_FS_1000dps_TO_mdps(lsb) (float)(lsb * 35.0f)
    #define LSM6DSL_FROM_FS_2000dps_TO_mdps(lsb) (float)(lsb * 70.0f)
    Are you facing errors during compiling phase? Regards
    Eleon BORLINI
    louiey
    louieyAuthor
    Apr 20, 2019 6:26 AM UTC
    Yes, thank you for "define".
    Still I couldn't find ehse info from "https://github.com/STMicroelectronics/STMems_Standard_C_drivers/blob/master/lsm6dsl_STdC/driver/lsm6dsl_reg.h".
    Anyway I could go head.
    Thanks.
    louiey
    louieyAuthor
    Apr 20, 2019 6:25 AM UTC
    Thanks.
