LSM303AGR Temperature sensor issue
When the LSM303AGR temperature is changing over time we see flat spots in the temperature readings at 24degC and every 16deg above and below this, with 24deg being the most noticeable. Other readings appear to be normal.
We have tested in a temperature chamber (heating and cooling cycles), but this can also be seen when allowing the device to warm up naturally on a bench. The following graph show temperature values returned from the device over the first 16 minutes after powering on the device.
Any ideas?
