APate.19
LSM303AGR Magnetometer result is deviated when iron comes nearby
we have used LSM303AGR  magnetometer for cupboard Door Open/Close detection and it is working properly.
On door close position, i am getting ~0 of every direction as i have done hard iron compensation.
Issue i am getting in small cupboard is to open the door, door handle is required to rotate. when handle is rotated completely, Handle iron comes near magnetometer IC and due to that result is deviated.
Is there any solution for that?
Logic implemented to detect door Open/Close position:
  1. Calibration process:Close the door and calibrate it.at that position magnetometer gives ~0 value of each direction as i have done hard iron compensation.
  2. Door Open: when any magnetometer axis value is beyond 50 value.
  3. Door Close: when every magnetometer axis value is below 15 value.
Ozone
Principal
January 30, 2020
Depends on how you view the problem.
The effect is intrinsic to magnetometers - they measure a magnetic field, wherever it comes from.
But you can calibrate the sensor (search for "soft iron calibration"). Like e.g. here:
https://www.instructables.com/id/Easy-hard-and-soft-iron-magnetometer-calibration/
https://diydrones.com/profiles/blogs/advanced-hard-and-soft-iron-magnetometer-calibration-for-dummies
https://pdocs.kauailabs.com/navx-mxp/guidance/magnetometer-calibration/
APate.19
APate.19Author
Thanks Ozone,
I observed another issue like magnetometer value changes after sometimes at same location.
Initially:
Fri 11/22/2019 18:27:54.801 : X : -4, Y : 0, Z : -3
After:
Thu 01/30/2020 18:58:06.330 : X : 18, Y : -5, Z : 31
Can you please help what is going wrong?
APate.19
APate.19Author
Can you please help what is going wrong in below mentioned case?
magnetometer value changes after some days at same location and same position.
Initially:
After:
