LSM303AGR accelerometer readings problem
- 3 replies
- 1720 views
Hi all,
I'm trying to interface a LSM303AGR, to get the magnetometer and accelerometer values in I2C.
The component is responding well to whoami requests (both compass and magnetometer parts), I manage to get mag values but the accelerometer values seems to be stuck.
Here are my init parameters:
REBOOT
ACCELEROMETER
MEMORY
CONTENT
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG5_A
0x80
RTC_wait_ms
6
REBOOT
MAGNETOMETER
MEMORY
CONTENT
I2C_Write_reg
I2C2
I2C_LSM3_MAG_ADRESS
1
I2C_LSM3_CFG_REG_A_M
0x40
RTC_wait_ms
6
void
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_WHO_AM_I_ACC
whoamiacc
1
if
whoamiacc
0x33
FAIL(
'LSM303AGR
accelerometer
side
isn't
responding'
else
ACCELEROMETER
INITIALIZATIONS
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG1_A
0x57
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG2_A
0x00
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG3_A
0x00
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG4_A
0x98
//BDU
ON
+/-4G
Range
and
High
res
ON
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
0x00
void
I2C_Read
I2C2
I2C_LSM3_MAG_ADRESS
1
0
I2C_LSM3_WHO_AM_I_MAG
whoamimag
1
if
whoamimag
0x40
FAIL(
'LSM303AGR
magnetometer
side
isn't
responding'
else
MAGNETOMETER
INITIALIZATIONS
I2C_Write_reg
I2C2
I2C_LSM3_MAG_ADRESS
1
0x8C
I2C_Write_reg(I2C2,I2C_LSM3_MAG_ADRESS
1,I2C_LSM3_CFG_REG_B_M,0x02);
My reading fonction for the accelerometer is the following:
uint8_t
drdy
0
uint8_t
x_accel
2
0
uint8_t
y_accel
2
0
uint8_t
z_accel
2
0
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_STATUS_REG_A
drdy
1
if
drdy
0x01
0x01
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_OUT_Y_L_A
y_accel
2
if
drdy
0x02
0x02
) I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_OUT_Z_L_A
z_accel
2
if
drdy
0x04
0x04
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_OUT_X_L_A
x_accel
2
I get the exact same answer at every reading:
x_accel
0
= 0xA0
x_accel
1
= 0xA0
y_accel
0
= 0xC0
y_accel
1
= 0xC0
z_accel
0
= 0x40
z_accel
1
= 0x40
Am I doing something wrong in the initializations? I would like the accelerometer to be in +/-4G range, 100Hz, without FIFO and in High res mode.
The I2C_Read function seems to work well, my function reading the magnetometer works fine.
Thank you!
