Antypas.Peter
Senior
August 16, 2016
LPS25HB single point calibration after soldering
Posted on August 16, 2016 at 19:32
I am trying to produce 6 matched sensors. I have soldered them and I can query them via I2C, but their values are significantly off true air pressure. I know I'm supposed to use the RPDS_L and RPDS_H registers, but the data sheet does not clarify what that offset represents and what the units are. I thought at first that it was supposed to be multiples of 4096 like normal readings, but it doesn't appear to be so. Please clarify.
Thanks.
#lps25hb
