caferacer
Nov 4, 2024 10:40 AM UTC
LPS25HB barometer - is it temperature compensated?
Hi. I have two LPS25HB on PCB board. After I cooling them with room air, they show signifacant drop in pressure readings. Do they have full temperature compensation? Are compensation registers protected from accidental erasure?
Andrew Neil
Nov 4, 2024 11:04 AM UTC
caferacer
caferacerAuthor
Nov 4, 2024 12:13 PM UTC
I thought so too. Then what is this drops on the pressure graph?
Andrew Neil
Nov 4, 2024 12:46 PM UTC
If you're blowing on them, that will affect the pressure ...
