tve
LPS22HB LC_EN (low current mode enable)
Is there any application note or other information available about the LPS22HB's low current mode, as enabled by LC_EN in RES_CONF register? Other than reducing power consumption, what does it do and specifically, how does it affect performance?
Federica Bossi
Hi @tve ,
In low current, all filtering and averaging that is computationally relevant in terms of current is ignored. This certainly increases the accuracy of the output data.
tve
tveAuthor
Thanks for the reply, I assume you meant "decreases the accuracy"?
