LMS6DSV320X peak tracking ODR
Hi ST Community,
Neither the LSM6DSV320X datasheet nor the FSM application note AN6291 clearly specifies the sampling rate at which the peak-tracking feature processes the high-g accelerometer data.
Our application is focused on shock detection. We would like to operate the high-g accelerometer at its maximum ODR of 7.68 kHz to capture short-duration shock events. However, to reduce the amount of data transferred to the host MCU, we only want to store the maximum acceleration vector detected within each 100 ms measurement window (i.e., 10 peak samples per second).
The sensor's FSM and integrated peak-tracking feature appear to provide all the functionality required to implement this directly within the sensor.
However, the documentation does not clearly indicate whether the peak-tracking feature processes the high-g accelerometer data at:
The configured FSM ODR (maximum 960 Hz), potentially missing short shock peaks between FSM processing cycles.
The configured high-g accelerometer ODR (maximum 7.68 kHz), with the FSM only controlling the start and stop of each peak-tracking measurement window.
Could you please clarify how the internal peak-tracking feature operates, particularly which clock or ODR determines its effective sampling rate?
Specifically, if the high-g accelerometer is configured at 7.68 kHz and the FSM at 960 Hz, does the peak-tracking feature evaluate all high-g samples, or only those available at the FSM processing rate?
This distinction is critical for determining whether the feature is suitable for reliably capturing short-duration shock events in our application.
Thank you in advance for your support.
