June 9, 2015
LIS3DSH noise problem
- 0 replies
- 713 views
Posted on June 09, 2015 at 15:36
I am using LIS3DSH accelerometer, sampling rate 100HZ scale = +-2G. What I see is from time to time is noise what is coming from one of the axis, I tried to add more decoupling caps, thy to change internal filter settings nothing helps.Please see attached for your reference.Thank you for the help.Regards,Andrew
