Ahmed Ben Amara
May 11, 2018 10:17 AM UTC
Lis3dsh no longer respond
Posted on May 11, 2018 at 12:17
In my application , i switch between power down and other data rate sometimes each second and i use soft reset before to reset the lis3dsh in Reg3 ,sometimes it takes many days to have the lis3dsh not responding and sometimes before it takes less than that. i tried to read registers it always returns 0xff i checked with my oscislloscope MISO is always high.
I tried to do as mentioned here
https://community.st.com/0D50X00009XkWy7SAF
 always no good result.when i tried to unpower the LIS3DSH and power it again it works well and the device respond again and the read write works fine.My problem is that in my application the hardware forces me to use only the software reset the VDD is not controlled.
Could i have a explication for that issue? Thank you
##lis3dsh
