radoslaw
November 18, 2014
LIS3DH wrong behavior after writing to CTRLREG6
Posted on November 18, 2014 at 19:53
Some day ago I've started work with LIS3DH accelerometer. Everything works fine -
Reading accelerations, highpass filter, low power mode and INT1 interrupt line.
At start INT1 was configured as high when active (CtrlReg6 = 0x00 - default value)
I want to inverse polarity of INT1 so I send 0x02 to CtrlReg6. Until that, every register which I set before has value = 0x00, also CtrlReg6.
Registers are written in orderly:
CtrlReg1,2,3,4,5,6
I read errata, datasheet and application note and I didn't find any information which could help in that problem.
Has anyone seen similar behavior and have some tips how to fix that issue?
Thanks a lot.
Radek
until I send data do CTRLREG6.
