Mich1
Dec 19, 2013 4:28 PM UTC
LIS3DH SPI pull-up values?
Posted on December 19, 2013 at 17:28
In LIS3DH datasheet (Doc ID 17530)
on figure 3 page 12/42 we can see: ''When no communication is on-going, data on CS, SPC, SDI and SDO are driven by internal pull-up resistors.''
What is the pull-up value?
Are these pull-up still active if the LIS3DH is put in power down mode?
#lis3dh-spi
Mich1
Mich1Author
Feb 22, 2017 3:47 PM UTC
Posted on February 22, 2017 at 16:47
Still no support from STµ about the LIS3DH spi pull-up values?
Why is there a pull-up on SDA???? How can I guarantee that the last data bit from the microcontroller is a 1????
Feb 23, 2017 9:29 AM UTC
Posted on February 23, 2017 at 09:29
Please check the latest version of the datasheet for
http://www.st.com/resource/en/datasheet/lis3dh.pdf
The datasheet says 'When no communication is ongoing, data on SDO is driven by internal pull-up resistors'.
So the pull-up is only on SDO/SA0 pin, the pull-up value can be found in chapter 1.1 and it can be disabled in CTRL_REG0.
Mich1
Mich1Author
Jun 14, 2017 5:48 PM UTC
Posted on June 14, 2017 at 17:48
Is this pin still driven when the LIS3DH is in Power-Down mode (ODR=000 in CTRL_REG1)
