colleague
LIS3DH read sequence 1sec...
Posted on December 15, 2014 at 16:09
hi all
I want to use long periodic reading 3 axises.
I configurate the LIS3DH
using by reference source code
ODR = 100Hz
Normal_power mode
turn on the x,y and z enable.
then now I read 3 items for 1 sec period.
It happended Overrun...I read 16th or 14th  it occured the reset...
It means all parameter value reset to zero.
So I want to use BDU(Block Data Update) or any possible method?
what should I do?
