emariatos
LIS3DH power consumption too high
Posted on July 31, 2012 at 20:12
We use LIS3DH at 10Hz, with FIFO, low power mode, I2C for communication. We measure current at we get:
- at 3.6V supply, 160uA
- at 3.0V supply, 100uA
- at 2.3V supply 60uA
The datasheet claims 6uA, what might we be doing wrong?
#lis3dh
    jgaldana
    Posted on September 16, 2016 at 15:48
    Hi Support team,
    Since there is an internal pull-up on this pin, it could be left floating/disconnected and assume this solution is going to be reliable? or it must be tied to VCC?
    Thanks in advance,
    jgaldana
    Posted on September 19, 2016 at 15:24
    I am going to answer my own question. The answer is not. If this pin is left disconnected the ''pull-up'' is not strong enough and oscillates under certain conditions.
