peyman
June 12, 2015
LIS3DH FIFO Int generation
Posted on June 12, 2015 at 22:27
Hi all,
I am trying to use my LIS3DH in FIFO Stream mode.
I am trying to configure the accelerator to generate an interrupt whenever the FIFO is full.
However it never generates any interrupts.
I have configured the registers as following:
CTR_REG1= 0x57
CTR_REG2=0x00
CTR_REG3=0x02
CTR_REG4=0x08
CTR_REG5=0x48
FIFO_CTR_REG=80
I have noticed that when I read FIFO_SRC_REG for debugging the value is 0x20 which means that the FIFO is empty. Also when I read the value of FIFO_CTR_REG the value is 0x00!
any idea?
Regards,
Peyman
#lis3dh-fifo #lis3dh #lis3dh-interrupt
johnray9
November 17, 2015
Posted on November 17, 2015 at 16:33
Have you tried the chip in normal mode without fifo and can you see data values?
