ksrgopinath
LIS3DH click and double click configuration
Posted on July 05, 2012 at 14:55
The original post was too long to process during our migration. Please click on the attachment to read the original post.
    ksrgopinath
    Posted on July 10, 2012 at 13:00
    Hi guys,
              I have found the solution for this.In the application note CTRL_REG3 is metioned as the register to configure interruppt on INT1 pin but the correct configuration is use CTRL_REG6 bit 7 and bit 6(I2_CLICKen and I2_INT1) will enable tap and double tap interruppts on INT2 pin.(Tip:for tuning increase sampling rate (CTRL-REG1) increase time-limit value).
    rasimoguzturk
    Posted on November 07, 2012 at 10:38
    hi sri,can you post your I2C read write functions if possible?
