bognermn
July 8, 2015
LIS331HH data rate
Posted on July 08, 2015 at 14:00
does anybody know how accurate the data rate of the LIS331HH sensors should be? I use two with a data rate of 1000Hz of them and want to synchronize the measurment results. For this reason i measured the Interrupt Pin INT1 of both sensors. The first one has a data rate of 995Hz and the second one has a data rate of 1000Hz. Is there a tolerance value for the data rate of these sensores?
Best regards,
max
