LIS2MDL OSR rate
Hello
Does anyone know the signal Oversampling Rate/s?
I'm working for a Medtech company developing a novel device and we are thinking of using the LIS2MDL for our analysis. The data from the sensor will be analysed using different signal processing techniques such as FFT etc.
we would like to know the sample rate to assess whether LIS2MDL sensor is compatible with our requirements
Thank you
Federica Bossi
Hi @Indi ,
I don't understand your question.
The oversampling rate is not a parameter, I can give you the output data rate.
