Mar 24, 2025 10:06 PM UTC
lis2dwt12 SPI communication with other slaves present
I have lis2dwt12 sensor and nrf24l01+ sensor.Can i connect these devices on same spi line? i will select different CS pins.
Thank you for now.
Andrew Neil
Andrew NeilBest answer
Mar 25, 2025 4:27 PM UTC
@Garslanbay wrote:
 I haven't been able to read the NRF24L01+ registers at all.
Can you communicate with it on its own - ie, with the LIS2DWT12 disconnected?
You can disable the I2C in the LIS2DWT12:
Andrew Neil
Mar 25, 2025 8:26 AM UTC
Yes, that is the whole point of SPI as a bus.
Mar 25, 2025 3:49 PM UTC
But I couldn't get it to work. I know that different models exist, and I adjusted accordingly. The common pins like SCK, MOSI, MISO are the same. I haven't been able to read the NRF24L01+ registers at all.
I had this thought: could it be that when I set the CS pin of the LIS2DWT12 sensor High, it switches to I2C and is preventing my communication with the NRF?
Andrew Neil
