lis2dw12
Posted on May 28, 2018 at 09:24
Hi everyone,
I am using lis2dw12 accelerometer in my design.
When i use STEVAL-MK179V1 with my custom board, the power consumption of LIS2DW12 seems normal.
However, if i use LIS2DW12 IC soldered to my custom board, the power consumption increase to much.ow ca
I took the power consumption measurements while ACC is in power down mode. I configured the CS pin as output high and INT1 pin as input pull down. INT2 pin is not connected to anything.
How can i solve my problem?
Have a nice day
