Benjamin Becker
August 1, 2017
LIS2DS12 - Does Wake Up interrupt block other interrupts
Posted on August 01, 2017 at 21:23
I'm trying to configure my LIS2DS12 accelerometer such that I can receive both wake and tap events. Whenever I enable (set the INT1_WU pin in ctrl4) I don't get tap events. I have three cases:
1. enable just the wake up interrupt: wake up interrupts occur
2. enable just the double tap event: tap interrupts occur
3. enable both the double tap and wake up interrupts: only wake up events occur.
Is there a way to be able to see both interrupts?
Register values when I try to configure both interrupts:
status: 0000, 1001 [FIFO_THS][WU_IA][SLP_STATE][DTAP]--[STAP][6D_IA][FF_IA][DRDY]
statdu: 0000, 1001 [OVR][WU_IA][SLP_STATE][DTAP]--[STAP][6D_IA][FF_IA][DRDY]
func_ck: 0000, 0000 [TILT_INT][FS_SRC][SIG_MOT]--[RST_SIG_MOT][RST_PED][STP_DET][GATE_FUNC]
tapsrc : 0010, 0100 [0][TAP_IA][STAP][DTAP]--[TAPSGN][XTAP][YTAP][ZTAP]
wkupsrc: 0000, 0000 [0][0][FF_IA][SLP_STAT]--[WU_IA][X_WU][Y_WU][Z_WU]
6d src: 0010, 0000 [0][6d_IA][ZH][ZL]--[YH][YL][XH][XL]
wkupths: 10, 4 [SINGLE_DOUBLE_TAP][SLEEP_ON]--[WU_THS]
wkupdur: 0 0, 0 0 [FF_DUR5][WU_DUR]--[INT1_Fss7][SLEEP_DUR]
ctrl1: 6, 200 [ODR]--[FS][HF_ODR][BDU]
ctrl2: 0000, 0100 [Boot][SOFT_RESET][0][FUNC_CFG_EN]--[FDS_SLOPE][IF_ADD_INC][I2C_DISABLE][SIM]
ctrl3: 011, 1100 [ST2:1][TAP_X_EN][TAP_Y_EN]--[TAP_Z_EN][LIR][H_LACTIVE][PP_OD]
ctrl4: 0010, 1000 [INT1_MASTER_DRDY][INT1_S_TAP][INT1_WU][INT1_FF]--[INT_TAP][INT1_6D][INT1_FTH][INT1_DRDY]
fifoctrl: 00, 0000 [FMODE[2:0]][INT2_SETP_COUNT_OV]--[MODULE_TO_FIFO][0][0]IF_CS_PU_DIS]
