LIS2DE12 configuration for interrupt when going from stillness to motion and vice versa
Hi.
I'm having difficulties understanding how to configure the LIS2DE12. Especially the filter part is obscure to me.
I want the accelerometer to generate an interrupt when the device changes from being still to moving or the opposite.
The power consumption should be as low as possible, so an ODR of 1hz has been chosen, and also smaller movement should be filtered out. That means the device should have been moving for at least 5 minutes after having being still or vice versa before generating an interrupt.
I hope someone is able to help.
Thanks.
