NItin Kanani
LIS2DE12
Posted on January 04, 2018 at 08:44
I am interfacing sensor with Micro controller and controller is working at +3.3V.
VDD_IO and VDD are two power supply pins in sensor.
If i am giving common supply +3.3V of controller to VDD_IO and VDD , will it work?
OR
Do i need to give seperate voltages for both supply pins?
Suggest me.
Thanks.
Posted on January 04, 2018 at 09:19
Yes, it will work. You can tie VDD_IO and VDD together and connect both to 3.3V.
