Lenses for STHS34PF80 IR Sensor
We are currently in the process of developing a device that contains the STHS34PF80 IR sensor. After study of the datasheet and conducting our own tests, we have found that the sensor reliably detects a person within a 4-meter range. However, for our project requirements, we need an extended detection range of 10 meters.
We understand that one way to achieve this goal is to use appropriate lenses to enhance the sensor's capabilities. We would greatly appreciate your recommendations on which lenses would be suitable for extending the range of the STHS34PF80 sensor to meet our specific needs.
Peter BENSCH
Peter BENSCHBest answer
You could get in contact with the supplier FresnelFactory and check their Long range lense.
Hope that helps?
Good luck!
/Peter
Peter BENSCH
Hope that helps?
Good luck!
/Peter
