L3GD20H Motion Sensor
I am using the L3GD20H Motion Sensor for flight application and I need to compensate for temperature variation. There is a registry that I can read that provides a temperature value. Could you tell me what this value means and what it is referenced to? At 22C the value is 5, when I freeze the chip the value is around 14. How is this value used to correct the reading as a function of temp?
Regards,
