SUT
It it possible to use BCN002V1 as bluetooth gateway ?
    Eleon BORLINI
    Hi @SUT​ , if you intend to use the BCN002V1 as a data gateway from BLE to e.g. wifi/ethernet, or a hub for other BCN002V1, I'm aftaid it in not possible. You should use for example a raspberry pi as gateway, enabling you to collect data sent by different BCN002V1 boards via BLE and redirecting them to another net. Regards
    SUT
    SUTAuthor
    I mean receiving data from different BLE/BCN002V1 modules and then push over UART/SPI not over internet, is it possible?
    Eleon BORLINI
    ​yes you can receive data from multiple BCN002V1 via BLE, but you need a proper hub to manage the gateway, such as a raspberry pi. you cannot use another BCN002V1 (as hub or master) to collect the other BCN002V1. Regards
