kumarnaveenb
ISM330DHCX with MLC enable sensor will not start until Power On reset.
I am trying MLC core examples. First time I program I can bale to debug the ISM330DHCXTR + Nucleo 401RE board successfully. If I reinitialize debug session, the debugger stuck at while loop below.
 do {
    ism330dhcx_device_id_get(&dev_ctx, &whoamI);
    HAL_Delay(500);
My Observations,
  1. I2C working perfect with 400kHz
  2. MLC core makes some way ISM330DHCXTR unstable state.
  3. After power On reset, everything works perfectly.
  4. If I run normal/Polling for accelerometer and Gyro data, works perfect.
Can had same issue. Any help around this issue will be a great help.
Thanks,
Naveen
    Eleon BORLINI
    Hi @NK.1umar Byregowda​ Naveen,
    did you just added the MLC code to your project?
    Could you share that part of the code so that I can share to our experts?
    -Eleon
