VPerr.1
ISM330DHCX : is it possible to find any Electronic Image Stabilization application note?
Examples of EIS application for this IMU (or a similar one) could be usefull.
Any other interesting IMU for UAV payload integration ?
Best regards
Eleon BORLINI
Hi @VPerr.1​ ,
did you already consulted this Optical Image Stabilization (OIS) white paper? If not, please have a look at it. It explains the general settings for the EIS / OIS, especially in the Architecture description sectio, from p.10.
You can also check the ism330dhcx_reg.c file on Github, where you can find the C drivers for the direct setting of the OIS register of the ISM330DHCX device.
-Eleon
Eleon BORLINI
Hi @VPerr.1​ ,
do you have any update about your application?
You can also refer to the "UAV section" on st.com, that is focused on Drones for industrial application or gaming.
-Eleon
