ISM330BX datasheet error. In AN6109 (device application note)
anyone know who to contact about an error in the datasheets?
In the AN6109 (device application note) of the ISM330BX datasheet on page 65/107 in section 8.2 FIFO registers there are three line I believe have errors:
– SFLP_GBIAS_FIFO_EN bit of the EMB_FUNC_FIFO_EN_B register in order to enable batching the gyroscope bias data in FIFO (the SFLP embedded function must be enabled)
– SFLP_GRAVITY_FIFO_EN bit of the EMB_FUNC_FIFO_EN_B register in order to enable batching the gravity vector data in FIFO (the SFLP embedded function must be enabled)
– SFLP_GAME_FIFO_EN bit of the EMB_FUNC_FIFO_EN_B register in order to enable batching the game rotation vector data in FIFO (the SFLP embedded function must be enabled)
these three lines should say EMB_FUNC_FIFO_EN_A register not EMB_FUNC_FIFO_EN_B register.
also, and this part I'm less sure about, on the same document on page 57/107 in section 6.5 Sensor fusion functions I think the "the specific configuration below must be applied after the device boot" specifically this line:
4. Write D2h to PAGE_ADDRESS
either it shouldn't be D2h or I am just brain farting and misreading the "Table 5. Embedded advanced features registers - page 1" section
Thanks.
Federica Bossi
Federica BossiBest answer
Hi @no_it ,
Thank you for bringing this to our attention. I will ask the team to check and correct it if necessary.
Federica Bossi
Hi @no_it ,
